[Geoserver-devel] [jira] Created: (GEOS-699) WMS base map option
WMS base map option
                 Key: GEOS-699
                 URL: http://jira.codehaus.org/browse/GEOS-699
             Project: GeoServer
          Issue Type: New Feature
            Reporter: Brent Owens
         Assigned To: Brent Owens
            Priority: Minor
             Fix For: 1.3.4, 1.4.0-RC0
Allow the user to specify a list of BaseMap layers that will be the default map. This map is used when the user makes a WMS getMap request specifying "LAYERS=basemap".
The list of layers is editable through the UI and the user can also edit the default styles to use.
