[Geoserver-devel] [jira] Created: (GEOS-704) KML reprojection
KML reprojection
                 Key: GEOS-704
                 URL: http://jira.codehaus.org/browse/GEOS-704
             Project: GeoServer
          Issue Type: Improvement
    Affects Versions: 1.4.0-M0
            Reporter: Brent Owens
         Assigned To: Brent Owens
             Fix For: 1.4.0-RC0
Add reprojection to KML.
Might need to create a simple Decimator that does not decimate (remove close vertices from) geometries. KML isn't raster so we want to keep all points.
Problem solved in 1.4.x - WCS branch.
On 8/31/06, Brent Owens (JIRA) <jira@anonymised.com> wrote:
KML reprojection
Key: GEOS-704
Project: GeoServer
Fix For: 1.4.0-RC0
Might need to create a simple Decimator that does not decimate (remove close vertices from) geometries. KML isn’t raster so we want to keep all points.
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-devel mailing list
Eng. Alessio Fabiani
Vice President/CTO GeoSolutions
Excellent!
And after all that work :stuck_out_tongue:
Oh well, I learned a lot.
Brent Owens
(The Open Planning Project)
On 8/31/06, *Brent Owens (JIRA)* <jira@anonymised.com <mailto:jira@anonymised.com>> wrote:
    KML reprojection
                     Key: GEOS-704
                 Project: GeoServer
                 Fix For: 1.4.0-RC0
    administrators:
    <http://jira.codehaus.org/secure/Administrators.jspa&gt;
    security?
    job easier
    Geronimo
    <http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642&gt;
    <mailto:Geoserver-devel@lists.sourceforge.net>
    <https://lists.sourceforge.net/lists/listinfo/geoserver-devel&gt;
Can you let us know when you fix KML stuff on that branch? It's the main thing we're working to refine these days.
How aligned are the two right now? We commented out some of the code for coverages, and then redid some. Are they somewhat aligned now or just different? I want to be sure we don't end up fixing lots of stuff in multiple places, as it is Brent spent time on this when you already had done it - I'd like to avoid that as much as possible in the future. We'll just have him use your code directly, so you won't need to align for something you already did.
Chris
    KML reprojection
                     Key: GEOS-704
                 Project: GeoServer
                 Fix For: 1.4.0-RC0
    to keep all points.
    security?
    job easier
    Geronimo
--------------------------------------------------------- !DSPAM:1003,44f69fc057761219810056!
Chris Holmes
http://topp.openplans.org
They are fully aligned, I use ever the trunk code as a base for patches, bug-fixes and new features.
On 8/31/06, Chris Holmes < cholmes@anonymised.com> wrote:
Can you let us know when you fix KML stuff on that branch? It’s the
main thing we’re working to refine these days.
just different? I want to be sure we don’t end up fixing lots of stuff
had done it - I’d like to avoid that as much as possible in the future.
We’ll just have him use your code directly, so you won’t need to align
Chris
mailto:[jira@anonymised.com](mailto:jira@anonymised.com)> wrote:
KML reprojection
Key: GEOS-704
Project: GeoServer
Fix For: 1.4.0-RC0
to keep all points.
<http://jira.codehaus.org/secure/Administrators.jspa >
security?
job easier
Geronimo
<http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642>
<mailto: Geoserver-devel@lists.sourceforge.net>
< https://lists.sourceforge.net/lists/listinfo/geoserver-devel>
http://www.geo-solutions.it <http://www.geo-solutions.it>
Chris Holmes
