WMS GetFeatureInfo should work even if the SRS is not specified in the request
Key: GEOS-720
URL: http://jira.codehaus.org/browse/GEOS-720
Project: GeoServer
Issue Type: Bug
Components: WMS
Affects Versions: 1.4.0-M2
Reporter: Andrea Aime
Assigned To: Andrea Aime
Fix For: 1.4.0-M2
With geoserver 1.4.0 trunk and basic.zip configuration, the following request:
returns a service exception:
<?xml version="1.0" encoding="UTF-8" standalone="no" ?><!DOCTYPE
ServiceExceptionReport SYSTEM
"http://localhost:8080/geoserver/schemas//wms/1.1.1/WMS_exception_1_1_1.dtd">
<ServiceExceptionReport version="1.1.1"> <ServiceException>Argument
"sourceCRS" should not be null.</ServiceException>
</ServiceExceptionReport>
this is because the code assumes SRS is always specified in the source request and triggers an error if it's not.
Since it's not mandatory according to wms 1.1.1, this is a bug.
