[Geoserver-devel] [jira] Created: (GEOS-731) GeoServer should not require primary keys for oracle/db2
                 Key: GEOS-731
                 URL: http://jira.codehaus.org/browse/GEOS-731
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 1.4.0-M2
            Reporter: Chris Holmes
         Assigned To: Andrea Aime
            Priority: Blocker
             Fix For: 1.4.0-RC1
See thread: http://www.nabble.com/Oracle-views-disfunctional-with-1.3.4--tf2376356.html
GeoServer on GeoTools 2.1.x did not require primary keys on views. Now if there's not a primary key the default isn't to just use some other field for the fid, or to do some default non-stable id, but it is to completely bomb.
This is bad, we should restore the old behavior, or many more people just won't get things working with GeoServer the first time.
