[Geoserver-devel] [jira] Created: (GEOS-732) Data_dirs defined in the web.xml file are not picked up
                 Key: GEOS-732
                 URL: http://jira.codehaus.org/browse/GEOS-732
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 1.4.0-M2
            Reporter: Brent Owens
         Assigned To: Brent Owens
            Priority: Blocker
             Fix For: 1.4.0-RC1
Data directory locations specified in the web.xml file are not picked up.
Environment variable defined data_dirs are found however.
