web.xml not loaded properly in binary and windows distributions of 1.4
Key: GEOS-733
URL: http://jira.codehaus.org/browse/GEOS-733
Project: GeoServer
Issue Type: Bug
Components: Configuration
Affects Versions: 1.4.0-M2, 1.4.0-M1, 1.4.0-M0
Reporter: Brent Owens
Assigned To: Justin Deoliveira
Priority: Blocker
Fix For: 1.4.0-RC1
It appears that the web.xml file is not loaded when using the binary or windows distributions of geoserver 1.4.0-M2. (I haven't tried other distributions yet)
Testing in eclipse does not have this issue, it has to be a real installation.
You can test by changing the data directory or the output strategies in the web.xml file. When the server is loaded and runs, those changes are ignored.
It defaults to "BUFFER" strategy instead of PARTIAL-BUFFER, and the data directory is the "webapps" folder, not the one specified in web.xml.
I will need Justin's insight on this one to fix it.
[ http://jira.codehaus.org/browse/GEOS-733?page=all ]
Andrea Aime reopened GEOS-733:
Your fixes conflicted with a change of mine, and restoring yours I noticed the bug was not fixed
for two reasons:
- web.xml in the web module contains "serviceStratagy", so the lookup always ends up in NULL
- the same file has service names that are totally diffent from bean ids:
PARTIAL-BUFFER
BUFFER
SPEED
FILE
I've fixed the typo, but I guess you have to re-check the rest
Key: GEOS-733
Project: GeoServer
Issue Type: Bug
Affects Versions: 1.4.0-M0, 1.4.0-M1, 1.4.0-M2
Priority: Blocker
Fix For: 1.4.0-RC1
