Multiple geometry columns no longer recognized in the renderer
Key: GEOS-798
URL: http://jira.codehaus.org/browse/GEOS-798
Project: GeoServer
Issue Type: Bug
Affects Versions: 1.4.0-RC3
Reporter: Brent Owens
Assigned To: Brent Owens
Priority: Blocker
Fix For: 1.4.0-RC4
You can no longer tell the SLD which geometry to use when rendering. This is bad as it is crutial if you have very detailed geometry and you need to use the generalized version to improve performance.
SLDs can include this element:
<Geometry><ogc:PropertyName>my_geom</ogc:PropertyName></Geometry>
in the symbolizers. But if specified nothing is rendered and no error is thrown. If you remove that element from the symbolizer it works but uses the first geometry column.
I will investigate this further and hopefully provide more detail.
