Geoserver ignores CRS in geometry filters
Key: GEOS-805
URL: http://jira.codehaus.org/browse/GEOS-805
Project: GeoServer
Issue Type: Bug
Affects Versions: 1.4.0-RC3, 1.3.4
Reporter: Andrea Aime
Assigned To: Andrea Aime
The OGC spec allows a geometry filter (in GetFeature, Transaction, Lock) to specify a srs name, see the abstract geometry type definition:
<complexType name="AbstractGeometryType" abstract="true">
<annotation>
<documentation>
All geometry elements are derived from this abstract supertype;
a geometry element may have an identifying attribute (gid).
It may be associated with a spatial reference system.
</documentation>
</annotation>
<complexContent>
<restriction base="anyType">
<attribute name="gid" type="ID" use="optional"/>
<attribute name="srsName" type="anyURI" use="optional"/>
</restriction>
</complexContent>
</complexType>
Unfortunately gt2 filter handling totally ignores georeferences, being based solely on JTS.
To properly support this, quite a big change in gt2 is needed.
