[Geoserver-devel] [jira] Created: (GEOS-812) WMS GetLegendGraphic should output labels if no Rule is specified
                 Key: GEOS-812
                 URL: http://jira.codehaus.org/browse/GEOS-812
             Project: GeoServer
          Issue Type: Improvement
          Components: WMS
            Reporter: Bart van den Eijnden
         Assigned To: Gabriel Roldán
            Priority: Minor
When a GetLegendGraphic request comes in without a Rule, a picture illustrating all the Rules should be issued by the WMS. To make Rules distinguishable, it makes sense to add a label. There is a bit of consensus, since Deegree, Mapserver and Cubewerx do it this way.
Populate the label with Rule->Title, if not present fall back to Rule->Name.
See also the following thread:
http://lists.eogeo.org/pipermail/wms-dev/2004-May/000518.html
