Data directory broken. Geoserver still references webapps/conf when adding datastores
Key: GEOS-815
URL: http://jira.codehaus.org/browse/GEOS-815
Project: GeoServer
Issue Type: Bug
Affects Versions: 1.4.0-RC3
Reporter: Brent Owens
Assigned To: Brent Owens
Priority: Blocker
You can no longer add a new shapefile to geoserver if it is in the datadirectory. Geoserver is sitll looking at the webapps/conf/data directory, not the data_directory! This is apparent in the binary and windows install.
It doesn't seem to be the case for styles, just shapefiles.
