Error reporting is also not there anymore
Key: GEOS-816
URL: http://jira.codehaus.org/browse/GEOS-816
Project: GeoServer
Issue Type: Sub-task
Affects Versions: 1.4.0-RC3
Reporter: Brent Owens
Assigned To: Brent Owens
Priority: Blocker
Fix For: 1.4.0
When the file is missing, it no longer gives a proper error message, just repeats the shapefile name.
It needs to say "File not found", it is however throwing an error in the logs.
