AccessControlException in GeoserverDataDirectory.init
Key: GEOS-818
URL: http://jira.codehaus.org/browse/GEOS-818
Project: GeoServer
Issue Type: Bug
Affects Versions: 1.3.4
Environment: Ubuntu 6.10, Tomcat 5.5.
Reporter: Ken Geis
Assigned To: Andrea Aime
In org.vfny.geoserver.global.GeoserverDataDirectory.init(...) there is a call to System.getProperty(String). If the security manager is enabled on your servlet engine (the default for Tomcat on Ubuntu,) this call throws an exception. This exception should be caught. It should probably just be ignored or logged.
I saw this behavior in 1.3.4 and 1.4.0-RC4. I could not mark that it affects 1.4.0-RC4 in this Jira because that version is not there yet.
Also, the class should be called GeoServerDataDirectory.
