[Geoserver-devel] [jira] Created: (GEOS-822) Disabling output formats, making them more pluggable
                 Key: GEOS-822
                 URL: http://jira.codehaus.org/browse/GEOS-822
             Project: GeoServer
          Issue Type: Wish
            Reporter: Brent Owens
         Assigned To: Brent Owens
             Fix For: 1.5.x
A user brought up that they would like to disable some of the output formats, which currently isn't possible.
It could be useful if there was an on/off switch in the UI or a config file to edit.
On that note, the output formats should be more pluggable, so maybe a user can just drop in the jar.
