[Geoserver-devel] [jira] Created: (GEOS-831) Problem with custom schema.xml for defining FeatureType
                 Key: GEOS-831
                 URL: http://jira.codehaus.org/browse/GEOS-831
             Project: GeoServer
          Issue Type: Bug
          Components: Configuration
    Affects Versions: 1.4.0
         Environment: Linux Fedora Core 4, Tomcat 5.5, Java 1.5
            Reporter: Fabio Da Soghe
         Assigned To: dblasby
The problem arised when configuring a feature type with a custom schema.xml file.
I follow the procedure explained in the documentation, in page "Geoserver config files": I have a PostGIS table in my datastore, I don't create the FeatureType with the web admin but create a directory with the proper name in the data directory, then put into it the info.xml and schema.xml files (handwritten), with a custom GML Schema. Then I open Geoserver's web admin and hit "Load". All works fine: it loads the new configuration, I can see the new feature type and the WFS DescribeFeatureType request returns the right schema. I tested the WMS and WFS interfaces on these datas and all works perfectly, so I'm confident my info.xml and schema.xml files are correct.
Then I use the web admin to edit another already existent feature type (I change a trivial parameter, like the bounding box), hit "Apply", then "Save". Geoserver takes the new parameter correctly, but my custom schema.xml file is rewritten. If I repeat the DescribeFeatureType request I still get the correct result, but only because Geoserver has it in some cache: if I hit "Load" or restart Tomcat, the response gets corrupted.
