Geoserver cannot handle files outside the data dir anymore
Key: GEOS-853
URL: http://jira.codehaus.org/browse/GEOS-853
Project: GeoServer
Issue Type: Bug
Affects Versions: 1.5.0-beta1, 1.4.0
Reporter: Andrea Aime
Assigned To: Andrea Aime
Fix For: 1.4.1, 1.5.0
After a change on December 1, with changelog:
"removed requirement for shapefiles(data files) to be under the data/ sub-directory of the dara directory. It was searching for everything under data/, but really it should allow any location in the data directory"
Geoserver is no more able to handle files outside the data dir.
Basically, the old code assumed that if something starts with file://data is in the data dir, otherwise, keep the path unmodified.
The new code always prefixes the full data dir path, breaking the absolute paths.
