Misconfigured datastore prevents geoserver startup
Key: GEOS-893
URL: http://jira.codehaus.org/browse/GEOS-893
Project: GeoServer
Issue Type: Bug
Components: Configuration
Affects Versions: 1.5.0-beta2, 1.4.0
Reporter: Andrea Aime
Assigned To: Andrea Aime
Priority: Critical
Fix For: 1.4.1, 1.5.0-beta3
Connecting to a Geoserver 1.3.2 data directory may prevent Geoserver 1.4.0 onwards to start up at all.
Apparently, 1.3.2 allowed for no namespace specification in datastores, whilst 1.4.0 pretends it, and makes the whole geoserver crash if it's missing.
Here is a piece of a stack trace:
2007-2-6 16:55:01 org.springframework.web.context.ContextLoader initWebApplicationContext
ÑÏÖØ: Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'wfs' defined in URL [jar:file:/C:/Program%20Files/Apache%20Software%20Foundation/Tomcat%205.5/webapps/geoserver/WEB-INF/lib/wfs-1.4.0.jar!/applicationContext.xml]: Can't resolve reference to bean 'config' while setting property 'constructor argument'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'config' defined in URL [jar:file:/C:/Program%20Files/Apache%20Software%20Foundation/Tomcat%205.5/webapps/geoserver/WEB-INF/lib/main-1.4.0.jar!/applicationContext.xml]: Initialization of bean failed; nested exception is org.springframework.beans.factory.BeanInitializationException: Error creating xml config reader; nested exception is org.vfny.geoserver.global.ConfigurationException: org.vfny.geoserver.global.ConfigurationException: org.vfny.geoserver.global.ConfigurationException: there is no namespace defined for datatasore 'gdwy'
at org.vfny.geoserver.global.xml.XMLConfigReader.loadCatalog(XMLConfigReader.java:300)
at org.vfny.geoserver.global.xml.XMLConfigReader.load(XMLConfigReader.java:195)
at org.vfny.geoserver.global.xml.XMLConfigReader.<init>(XMLConfigReader.java:145)
at org.vfny.geoserver.global.Config.setApplicationContext(Config.java:43)
at org.springframework.context.support.ApplicationContextAwareProcessor.postProcessBeforeInitialization(ApplicationContextAwareProcessor.java:84)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:248)
If the spring context initialization fails, the whole geoserver startup fails...
