Message:
A new issue has been created in JIRA.
View the issue:
http://jira.codehaus.org/secure/ViewIssue.jspa?key=GEOS-90
Here is an overview of the issue:
Key: GEOS-90
Summary: FeatureType XML Definition
Type: Improvement
Status: Open
Priority: Minor
Original Estimate: Unknown
Time Spent: Unknown
Remaining: Unknown
Project: GeoServer
Versions:
1.2.0
Assignee: Chris Holmes
Reporter: Jody Garnett
Created: Thu, 5 Feb 2004 5:25 PM
Updated: Thu, 5 Feb 2004 5:25 PM
Description:
Chris this one wants your approval/understanding before anyone should work on it.
Section 2.3.3 VWFS Implementaiton Report
GeoServer currently uses XML Fragments for the schema.xml and info.xml
used to describe FeatureTypes. These fragments are stored in a directory based
on the FeatureType name.
Recommendations for FeatureType Definition:
- Use complete XML Documents for schema.xml and info.xml
- Remove orphaned <attributes> tag from info.xml.
- Store FeatureType configuration by DataStore Id
These changes would allow the use of a validating XML parser and prevent
FeatureType name conflicts across data sources.
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
