[Geoserver-devel] [jira] Created: (GEOS-911) Unable to parse emtpy filters in GET request
                 Key: GEOS-911
                 URL: http://jira.codehaus.org/browse/GEOS-911
             Project: GeoServer
          Issue Type: Bug
          Components: WFS, WMS
    Affects Versions: 1.5.0-RC1
            Reporter: Andrea Aime
         Assigned To: Andrea Aime
             Fix For: 1.6.0
A request like:
wfs?request=GetFeature&typeName=topp:states,tiger:tiger_roads&outputFormat=GML2&FILTER=(<Filter><FeatureId fid="states.3"/></Filter>)()
with the second filter emtpy won't be parsed properly, Geoserver will think there's only one filter and will apply it to every layer.
The issue is, the StringTokenizer used in KvpRequestReader will return just one token, being "()" just a coule of delimiters.
StringTokenizer does not have a notion of open and closed, fixing this would mean modifying parsing quite a bit, since we're under release and apparently nobody complained about this, we'll fix this on the next release.
Workaround: add a space between parenthesis and Geoserver will pick it up just fine.
