[Geoserver-devel] [jira] Created: (GEOS-913) hard to understand error message on coverage creation with coverageStore with bad or without corner coordinates
                 Key: GEOS-913
                 URL: http://jira.codehaus.org/browse/GEOS-913
             Project: GeoServer
          Issue Type: Bug
          Components: WCS
            Reporter: Vincent Schut
         Assigned To: Andrea Aime
When creating a coverage from a coverageStore (geotiff in my case) that accidentally lacks corner coordinate information, or e.g. has a full geotransform (all 6 numbers in the tfw file from which the geotiff tags were created are nonzero) instead of just UL corner coordinates and pixel size, will fail with a for the user incomprehensible nullPointer exception. For an example see the stack trace below (well, actually there is no stack trace generated, which makes it even more incomprehensible). This is a series of 4 attempts to create the coverage through the struts interface from the CoverageStore. It results in a blank screen with the NullPointerException being shown, and this in the tomcat logs:
Feb 12, 2007 3:40:26 PM org.apache.struts.action.RequestProcessor processException
WARNING: Unhandled Exception thrown: class java.lang.NullPointerException
Feb 12, 2007 3:45:51 PM org.apache.struts.action.RequestProcessor processException
Feb 12, 2007 3:47:16 PM org.apache.struts.action.RequestProcessor processException
Feb 12, 2007 4:11:08 PM org.apache.struts.action.RequestProcessor processException
