[Geoserver-devel] [jira] Created: (GEOS-926) When creating a CoverageStore, the default value for the URL field is wrong
                 Key: GEOS-926
                 URL: http://jira.codehaus.org/browse/GEOS-926
             Project: GeoServer
          Issue Type: Bug
          Components: Configuration
    Affects Versions: 1.5.0-RC1
            Reporter: Fabio Da Soghe
         Assigned To: dblasby
Chen I create a new CoverageStore, the configuration form (title " Coverage Data Set Editor") presents the URL field filled with the default value "file:data/coverages/", which for the default installation is wrong. It should be: "file:coverages/".
If the CoverageStore is created with wrong URL parameter, trying to create a Coverage on it leads to the following error:
GeoServer - Exception
The following exception was thrown:
java.lang.IllegalArgumentException: No input stream for the provided source
