Incorrect handling of period's in <PropertyName>
Key: GEOS-927
URL: http://jira.codehaus.org/browse/GEOS-927
Project: GeoServer
Issue Type: Bug
Components: ArcSDE, WFS
Affects Versions: 1.4.1, 1.4.0
Environment: RHEL4 / Win2003 / Tomcat 5x (All available environments)
Reporter: Chris Tweedie
Assigned To: Andrea Aime
I've found an interesting bug with the handling of period's in the PropertyName element which i hope someone could shed light on.
We're currently using a mix of postgis/arcsde layers on 1.4 and have switched on feature-level boundingbox generation for WFS.
We are sending the following query with the intention of getting feature names and only the bounding box (no actual geometry),
<wfs:GetFeature service="WFS" version="1.0.0" maxfeatures="10" outputFormat="GML2" xmlns:topp="http://www.openplans.org/topp" xmlns:wfs="http://www.opengis.net/wfs" xmlns:ogc="http://www.opengis.net/ogc" xmlns:gml="http://www.opengis.net/gml" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd">
<wfs:Query typeName="slip:LGATE-008">
<wfs:PropertyName>NAME</wfs:PropertyName>
<ogc:Filter>
<ogc:BBOX>
<ogc:PropertyName>GID</ogc:PropertyName>
<gml:Box srsName="http://www.opengis.net/gml/srs/epsg.xml#4283">
<gml:coordinates>115.777,-31.916 115.79,-31.897</gml:coordinates>
</gml:Box>
</ogc:BBOX>
</ogc:Filter>
</wfs:Query>
</wfs:GetFeature>
Gives us the following in the logs,
INFO: No FID attribute was contained in your query. Appending the discovered one to the list of columns to be fetched.
<gml:featureMember>
<slip:SDE.W_LAND_ADM_LOCALITIES_VIEW fid="SDE.W_LAND_ADM_LOCALITIES_VIEW.108">
<gml:boundedBy>
<gml:null>unknown</gml:null>
</gml:boundedBy>
<slip:NAME>INNALOO</slip:NAME>
</slip:SDE.W_LAND_ADM_LOCALITIES_VIEW>
</gml:featureMember>
This is understandably why no boundingbox is generated against the SDE datastore, but when we try to attach the fid attribute as requested,
<wfs:PropertyName>GID.FID</wfs:PropertyName>
Geoserver appears to strip the "GID." and tries instead to lookup an attribute of "FID" which results in
<ServiceException>
Requested property: FID is not available for slip:LGATE-008. The possible propertyName values are: [GID, USAGE_CODE, NAME, GID.FID]
</ServiceException>
Arghh!
If someone could point me in the direction of the offending bit of code - that would assist us greatly. Test service can be made available. Unfortunately we cannot alter the fid column name
Chris
