[Geoserver-devel] [jira] Created: (GEOS-938) Find out which projection we did loose switching from epsg-wkt to epsg-hsql and re-integrated them
                 Key: GEOS-938
                 URL: http://jira.codehaus.org/browse/GEOS-938
             Project: GeoServer
          Issue Type: Task
          Components: Configuration
    Affects Versions: 1.5.0-RC1
            Reporter: Andrea Aime
         Assigned To: dblasby
            Priority: Critical
             Fix For: 1.5.0-RC2
Checking a user issue I discovered that Geoserver 1.5.0 does not have EPSG:21781 any more.
I guess it's not the only one? We should check the list of known projections in 1.4.0, 1.5.0, and postgis too (since it seems that user has a good WKT string, with TOWGS84 parameters, coming from postgis).
