Message:
A new issue has been created in JIRA.
View the issue:
http://jira.codehaus.org/secure/ViewIssue.jspa?key=GEOS-94
Here is an overview of the issue:
Key: GEOS-94
Summary: Style Edit error
Type: Bug
Status: Open
Priority: Major
Original Estimate: 1 hour
Time Spent: Unknown
Remaining: 1 hour
Project: GeoServer
Fix Fors:
1.2-beta
Versions:
1.2-beta
Assignee: Richard Gould
Reporter: David Zwiers
Created: Mon, 9 Feb 2004 1:04 PM
Updated: Mon, 9 Feb 2004 1:04 PM
Environment: When http://localhost:8081/geoserver/DataConfigStyles.do is submitted.
Description:
The error occurs for any submission from http://localhost:8081/geoserver/DataConfigStyles.do .
java.lang.NullPointerException
at org.vfny.geoserver.action.data.DataStylesAction.execute(DataStylesAction.java:80)
at org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:98)
at org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:484)
at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:274)
at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1482)
at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:525)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:165)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:103)
at com.caucho.server.dispatch.ServletFilterChain.doFilter(ServletFilterChain.java:113)
at com.caucho.server.cache.CacheFilterChain.doFilter(CacheFilterChain.java:190)
at com.caucho.server.webapp.WebAppFilterChain.doFilter(WebAppFilterChain.java:177)
at com.caucho.server.dispatch.ServletInvocation.service(ServletInvocation.java:221)
at com.caucho.server.http.HttpRequest.handleRequest(HttpRequest.java:253)
at com.caucho.server.port.TcpConnection.run(TcpConnection.java:305)
at com.caucho.util.ThreadPool.run(ThreadPool.java:273)
at java.lang.Thread.run(Thread.java:534)
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
