[Geoserver-devel] [jira] Created: (GEOS-942) Batik rendering fails with ClassNotFound Error
                 Key: GEOS-942
                 URL: http://jira.codehaus.org/browse/GEOS-942
             Project: GeoServer
          Issue Type: Bug
          Components: WMS
    Affects Versions: 1.3.4
         Environment: Operating System: Linux on Opteron processor.
Container: Tomcat 5.5.4
Test URL:
http://www.add.scar.org:8080/geoserver/wms?VERSION=1.1.1&REQUEST=GetMap&LAYERS=cst10_polygon&STYLES=cst10polys&FORMAT=image/svg+xml&TRANSPARENT=TRUE&BBOX=-3329777.79,-3333134.03,3329777.79,3319715.82&WIDTH=500&HEIGHT=499&SRS=EPSG:3031
            Reporter: Alexander Paul Robin Cooper
         Assigned To: Gabriel Roldán
         Attachments: temp.out
SVG output with Batik rendering fails with Following error:
<?xml version="1.0" encoding="UTF-8" standalone="no" ?><!DOCTYPE ServiceExceptionReport SYSTEM "http://www.add.scar.org:8080/geoserver/schemas//wms/1.1.1/WMS_exception_1_1_1.dtd&quot;&gt;
<ServiceExceptionReport version="1.1.1">
<ServiceException code="">org/apache/batik/util/SVGConstants</ServiceException>
</ServiceExceptionReport>
Attachment gives traceback from log.
