[Geoserver-devel] [jira] Created: (GEOS-955) Capabilities requests compute bbox each time
                 Key: GEOS-955
                 URL: http://jira.codehaus.org/browse/GEOS-955
             Project: GeoServer
          Issue Type: Bug
            Reporter: Brent Owens
         Assigned To: Brent Owens
             Fix For: 1.5.0-RC2
The capabilities requests currently computes the bounding box for all the feature types each time it is requested. Have it grab the cached bbox instead if it exists.
                 Key: GEOS-955
             Project: GeoServer
          Issue Type: Bug
             Fix For: 1.5.0-RC2
One of my collegue partly solved the problem at the geotools level (so, no
caching at geoserver level), the result is just great!
Hope it will help (2.3.x/plugin/postgis/src/org/geotools/data/postgis
branch of geotools) :
$> diff patched-PostgisFeatureStore.java PostgisFeatureStore.java
972,979c972,973
< //sql.append("SELECT AsText(force_2d(Envelope(Extent(\"" + geomName
< //sqlBuilder.sqlFrom(sql, typeName);
< //sqlBuilder.sqlWhere(sql, filter);
< //LOGGER.fine("SQL: " + sql);
< // Francois Dubreil, 2007/03/07 : use of estimated_extent, available since
postigis 1.0.0
< // (quite close to the correct result and very much faster than Extent -
< // especially for large datasets ...)
< sql.append("SELECT
AsText(force_2d(Envelope(estimated_extent(\'"+typeName+"\',\'"+geomName +
        sql.append("SELECT AsText(force_2d(Envelope(Extent(\"" + geomName +
didier
                 Key: GEOS-955
             Project: GeoServer
          Issue Type: Bug
             Fix For: 1.5.0-RC2
One of my collegue partly solved the problem at the geotools level (so, no caching at geoserver level), the result is just great!
972,979c972,973
< //sql.append("SELECT AsText(force_2d(Envelope(Extent(\"" + geomName + "\")))) ");
< // Francois Dubreil, 2007/03/07 : use of estimated_extent, available since postigis 1.0.0
< sql.append("SELECT AsText(force_2d(Envelope(estimated_extent(\'"+typeName+"\',\'"+geomName + "\')))) ");
Yeah, we knew about estimated_extent, but its use is controversial because the returned bbox is not correct, just an estimate, and depends on you vacuuming the db every now and then.
I opened a geotools issue to have a new datastore parameter that allows enabling its usage (so that people that are ok with estimated boxes can use that one).
