[Geoserver-devel] [jira] Created: (GEOS-961) Better reporting of file errors on 'store' creation
                 Key: GEOS-961
                 URL: http://jira.codehaus.org/browse/GEOS-961
             Project: GeoServer
          Issue Type: Improvement
    Affects Versions: 1.5.0-RC2
            Reporter: Chris Holmes
         Assigned To: Chris Holmes
             Fix For: 1.5.0-RC3
Our file datastores and coverage stores have been bad at reporting errors at the time. Coverages got a bit better at reporting some errors, but the messages were still not that helpful. We should check to see if a file exists and try to read it, and if neither works report back what happened. This will help users out a lot. There are probably some further coverage improvements we could make, about the exact nature of the error, but this should go a long way.
