Message:
A new issue has been created in JIRA.
View the issue:
http://jira.codehaus.org/secure/ViewIssue.jspa?key=GEOS-97
Here is an overview of the issue:
Key: GEOS-97
Summary: Null pointer exception when trying to create new postgis datastore
Type: Bug
Status: Open
Priority: Major
Original Estimate: Unknown
Time Spent: Unknown
Remaining: Unknown
Project: GeoServer
Components:
Struts
Fix Fors:
1.2-beta
Versions:
1.2-beta
Assignee: Richard Gould
Reporter: Chris Holmes
Created: Tue, 17 Feb 2004 5:35 PM
Updated: Tue, 17 Feb 2004 5:35 PM
Environment: Resin, java 1.4.2, windowsXP
Description:
Seems to be that any postgis datastore that I try to enter gives me the same error. I'm currently using parameters of:
DataStore ID local
Enabled: checked
Namespace cdf
Description mine
host localhost
port 5432
database dcmms
user postgres
passwd postgres
charset utf-8
Then I get this:
http://localhost:8080/geoserver/DataConfigDataStoresSubmit.do
500 Servlet Exception
java.lang.NullPointerException
at org.vfny.geoserver.form.data.DataDataStoresEditorForm.validate(DataDataStoresEditorForm.java:157)
at org.apache.struts.action.RequestProcessor.processValidate(RequestProcessor.java:942)
at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:255)
at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1482)
at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:525)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:165)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:103)
at com.caucho.server.dispatch.ServletFilterChain.doFilter(ServletFilterChain.java:113)
at com.caucho.server.cache.CacheFilterChain.doFilter(CacheFilterChain.java:190)
at com.caucho.server.webapp.WebAppFilterChain.doFilter(WebAppFilterChain.java:177)
at com.caucho.server.dispatch.ServletInvocation.service(ServletInvocation.java:221)
at com.caucho.server.http.HttpRequest.handleRequest(HttpRequest.java:262)
at com.caucho.server.port.TcpConnection.run(TcpConnection.java:315)
at com.caucho.util.ThreadPool.runTasks(ThreadPool.java:353)
at com.caucho.util.ThreadPool.run(ThreadPool.java:302)
at java.lang.Thread.run(Thread.java:534)
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
