Improve KML reflector
Key: GEOS-977
URL: http://jira.codehaus.org/browse/GEOS-977
Project: GeoServer
Issue Type: Sub-task
Components: Google Earth KML Output
Affects Versions: 1.6.0-alpha2, 1.5.0-RC2
Reporter: Chris Holmes
Assigned To: Chris Holmes
Fix For: 1.5.1, 1.6.0
The KML reflector doesn't really pass through everything, but it should. We may be able to leverage the wms reflector. But it is built a bit differently. But either way, there are some improvements to be made. Should add ability to set the reload time from the params.
