Use File.isAbsolute to determine if a path is absolute
Key: GEOS-982
URL: http://jira.codehaus.org/browse/GEOS-982
Project: GeoServer
Issue Type: Bug
Components: Configuration
Affects Versions: 1.5.0
Reporter: Andrea Aime
Assigned To: Andrea Aime
Priority: Critical
Fix For: 1.5.1, 1.6.0
In GeoserverDataDirectory.findDataFile, use File.isAbsolute to determine if a path is absolute, or if it has to be prepended with the data dir. Won't do now because we're too close to the release.
