[Geoserver-devel] [JIRA] (GEOS-10015) Print extension is broken in recent versions
Mauro Bartolomeoli created an issue
GeoServer / ImprovementGEOS-10015
Issue Type:
ImprovementImprovement
Affects Versions:
2.19.0
Assignee:
Unassigned
Components:
Mapfish print
Created:
09/Apr/21 8:57 AM
Priority:
MediumMedium
Reporter:
Mauro Bartolomeoli
Calling http://localhost:8080/geoserver/pdf/info.json you get the following error:
javax.servlet.ServletException: org.springframework.web.util.NestedServletException: Handler dispatch failed; nested exception is java.lang.NoSuchMethodError: org.json.JSONWriter.<init>(Ljava/io/Writer;)V
This should be related to the json-20180813.jar library that has a breaking change on methods used by the printing extension.
See here how the mapfish-app application solved the same, reverting the library version:
https://github.com/georchestra/georchestra/pull/2517/files
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100156-sha1:ef05106)
Atlassian logo
