John Kristensen created an issue |
Incorrect login URL when using “Proxy Base URL” settings with " Use headers for Proxy URL" |
Issue Type: |
Bug |
Affects Versions: |
2.19.0 |
Assignee: |
Unassigned |
Created: |
27/Apr/21 11:28 AM |
Priority: |
Medium |
Reporter: |
I’m running Geoserver behind a reverse proxy and have set the “Proxy Base URL” settings to something like
which generate a login form with the following tag:
However if I tick the “Use headers for Proxy URL” setting, then the login form is generated with the following tag:
Usually this wouldn’t be a problem when using a “static” Proxy Base URL, but I would like to use a “dynamic” Proxy Base URL like
As best as I can tell the problem seems to be in the Commenting out that check seems to resolve the problem, but I’m not very familiar with the codebase, so have not idea what other side-effects removing it would cause. |
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS |
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100157-sha1:76eb1b6) |
