Exception in layer rendering for layers created from shapefile trying to define a new CSS style for them.
Step to reproduce the error:
- create a new workspace (test)
- create a new store (test) as shapefile directory
- create 1 or more new layers on the new store (test-line, test-point…)
- create a new CSS style (test)
- associate the new layers to the new style
- Click on Layer preview in style editor page
The following exception occurs: java.lang.ClassCastException: java.util.ArrayList cannot be cast to org.opengis.feature.type.AttributeDescriptor
Here the stack trace
org.geoserver.platform.ServiceException: Rendering process failed. Layers: test:1621319213245-point
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:658)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:272)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:133)
at org.geoserver.wms.GetMap.executeInternal(GetMap.java:749)
at org.geoserver.wms.GetMap.run(GetMap.java:300)
at org.geoserver.wms.GetMap.run(GetMap.java:123)
at org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:246)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:343)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:198)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:163)
at org.geoserver.kml.WebMapServiceKmlInterceptor.invoke(WebMapServiceKmlInterceptor.java:38)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:186)
at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:55)
at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:31)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:61)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:41)
at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:50)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:212)
at com.sun.proxy.$Proxy108.getMap(Unknown Source)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:876)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:265)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:177)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:52)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:1040)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:943)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:1006)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:898)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:687)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:883)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at org.eclipse.jetty.servlet.ServletHolder$NotAsync.service(ServletHolder.java:1452)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:791)
at org.eclipse.jetty.servlet.ServletHandler$ChainEnd.doFilter(ServletHandler.java:1626)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:26)
at org.eclipse.jetty.servlet.FilterHolder.doFilter(FilterHolder.java:193)
at org.eclipse.jetty.servlet.ServletHandler$Chain.doFilter(ServletHandler.java:1601)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:69)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:70)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:66)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:41)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:37)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:320)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:70)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:127)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:91)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:74)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:334)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:119)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:51)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilterInternal(BasicAuthenticationFilter.java:158)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:119)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:81)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:105)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:215)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:178)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:142)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:358)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:271)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:101)
at org.geoserver.filters.XFrameOptionsFilter.doFilter(XFrameOptionsFilter.java:77)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:47)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:46)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:42)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:201)
at org.eclipse.jetty.servlet.FilterHolder.doFilter(FilterHolder.java:201)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:548)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:602)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1624)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1435)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:501)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1594)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1350)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:191)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:146)
at org.eclipse.jetty.server.Server.handle(Server.java:516)
at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:388)
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:633)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:380)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:273)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105)
at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:375)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:773)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:905)
at java.lang.Thread.run(Thread.java:748)
Caused by: java.lang.ClassCastException: java.util.ArrayList cannot be cast to org.opengis.feature.type.AttributeDescriptor
at org.geotools.filter.FilterAttributeExtractor.visit(FilterAttributeExtractor.java:115)
at org.geotools.filter.AttributeExpressionImpl.accept(AttributeExpressionImpl.java:347)
at org.geotools.filter.visitor.DefaultFilterVisitor.visit(DefaultFilterVisitor.java:150)
at org.geotools.filter.IsEqualsToImpl.accept(IsEqualsToImpl.java:149)
at org.geotools.filter.visitor.DefaultFilterVisitor.visit(DefaultFilterVisitor.java:136)
at org.geotools.filter.OrImpl.accept(OrImpl.java:41)
at org.geotools.filter.visitor.DefaultFilterVisitor.visit(DefaultFilterVisitor.java:113)
at org.geotools.filter.AndImpl.accept(AndImpl.java:45)
at org.geotools.data.shapefile.ShapefileFeatureSource.getReadSchema(ShapefileFeatureSource.java:447)
at org.geotools.data.shapefile.ShapefileFeatureSource.getReaderInternal(ShapefileFeatureSource.java:315)
at org.geotools.data.shapefile.ShapefileFeatureStore.getReaderInternal(ShapefileFeatureStore.java:133)
at org.geotools.data.store.ContentFeatureSource.getReader(ContentFeatureSource.java:619)
at org.geotools.data.store.ContentFeatureCollection.features(ContentFeatureCollection.java:163)
at org.geotools.data.store.ContentFeatureCollection.features(ContentFeatureCollection.java:52)
at org.geotools.data.crs.ForceCoordinateSystemFeatureResults.openIterator(ForceCoordinateSystemFeatureResults.java:92)
at org.geotools.feature.collection.AbstractFeatureCollection.features(AbstractFeatureCollection.java:65)
at org.geotools.feature.collection.AbstractFeatureCollection.features(AbstractFeatureCollection.java:50)
at org.geotools.renderer.lite.StreamingRenderer.drawPlain(StreamingRenderer.java:2634)
at org.geotools.renderer.lite.StreamingRenderer.processStylers(StreamingRenderer.java:2269)
at org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:907)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:609)
… 141 more
