Gabriel Roldan created an issue |
Issue Type: |
Bug |
Affects Versions: |
2.19.0 |
Assignee: |
Unassigned |
Created: |
20/May/21 10:03 PM |
Priority: |
Medium |
Reporter: |
The currently used version of H2 database (1.1.119) does not survive abnormal server shutdowns (e.g. kill process) There have been other issues with it, like database corruption. Despite not being the recommended set up, the default should at least provide more consistency. In the past, using a newer H2 version (e.g. 1.4.199) solved the problem, as the database file format has been upgraded and is more robust. The problem is, IIRC, it is incompatible with 1.1.x existing databases, and a migration tool needs to be applied manually. There’s also a hint in the logs at startup that suggest an upgrade:
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS |
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100162-sha1:3b69042) |
