Mats Elfstrom created an issue |
Issue Type: |
Bug |
Affects Versions: |
2.19.1 |
Assignee: |
Unassigned |
Attachments: |
geoserver.log |
Components: |
Community modules |
Created: |
26/May/21 11:06 PM |
Environment: |
Geoserver 2.19.1 under Tomcat 9 and AdoptopenJDK 11 |
Priority: |
High |
Reporter: |
Installing the Metadata module (geoserver-2.19-SNAPSHOT-metadata-plugin.zip) breaks Geoserver which fails to start. Previously I added the INSPIRE module, the csw module and the csw-iso module. These installed and started correctly. geoserver.log
Here is the offending part of the log:
2021-05-26 22:35:03,344 WARN [support.XmlWebApplicationContext] - Exception encountered during context initialization - cancelling refresh attempt: org.springframework.beans.factory.UnsatisfiedDependencyException: Error creating bean with name 'metaDataRestService': Unsatisfied dependency expressed through field 'bulkService'; nested exception is org.springframework.beans.factory.UnsatisfiedDependencyException: Error creating bean with name 'metaDataBulkServiceImpl': Unsatisfied dependency expressed through field 'templateService'; nested exception is org.springframework.beans.factory.UnsatisfiedDependencyException: Error creating bean with name 'metadataTemplateServiceImpl': Unsatisfied dependency expressed through field 'metadataService'; nested exception is org.springframework.beans.factory.UnsatisfiedDependencyException: Error creating bean with name 'complexMetadataServiceImpl': Unsatisfied dependency expressed through field 'configService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'configurationServiceImpl': Invocation of init method failed; nested exception is java.lang.NoClassDefFoundError: org.yaml.snakeyaml.error.YAMLException
From here, it is just shutting down. I attach the entire log.
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS |
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100162-sha1:df22007) |
