[Geoserver-devel] [JIRA] (GEOS-10088) Crash on FreeBSD 12.2 x64
Serge created an issue
GeoServer / BugGEOS-10088
Issue Type:
BugBug
Affects Versions:
2.19.0, 2.19.1
Assignee:
Unassigned
Created:
03/Jun/21 2:16 PM
Environment:
FreeBSD 12.2 on VPS 2 core, 8g RAM, 80G HD
INFO: ===============================================================================
INFO: Marlin software rasterizer = ENABLED
INFO: Version = [marlin-0.9.3-Unsafe]
INFO: sun.java2d.renderer = org.marlin.pisces.MarlinRenderingEngine
INFO: sun.java2d.renderer.useThreadLocal = true
INFO: sun.java2d.renderer.useRef = soft
INFO: sun.java2d.renderer.edges = 4096
INFO: sun.java2d.renderer.pixelWidth = 4096
INFO: sun.java2d.renderer.pixelHeight = 2176
INFO: sun.java2d.renderer.profile = quality
INFO: sun.java2d.renderer.subPixel_log2_X = 8
INFO: sun.java2d.renderer.subPixel_log2_Y = 3
INFO: sun.java2d.renderer.tileSize_log2 = 6
INFO: sun.java2d.renderer.tileWidth_log2 = 7
INFO: sun.java2d.renderer.blockSize_log2 = 5
INFO: sun.java2d.renderer.forceRLE = false
INFO: sun.java2d.renderer.forceNoRLE = false
INFO: sun.java2d.renderer.useTileFlags = true
INFO: sun.java2d.renderer.useTileFlags.useHeuristics = true
INFO: sun.java2d.renderer.rleMinWidth = 64
INFO: sun.java2d.renderer.useSimplifier = false
INFO: sun.java2d.renderer.usePathSimplifier= false
INFO: sun.java2d.renderer.pathSimplifier.pixTol = 0.125
INFO: sun.java2d.renderer.clip = true
INFO: sun.java2d.renderer.clip.runtime.enable = false
INFO: sun.java2d.renderer.clip.subdivider = true
INFO: sun.java2d.renderer.clip.subdivider.minLength = 100.0
INFO: sun.java2d.renderer.doStats = false
INFO: sun.java2d.renderer.doMonitors = false
INFO: sun.java2d.renderer.doChecks = false
INFO: sun.java2d.renderer.useLogger = false
INFO: sun.java2d.renderer.logCreateContext = false
INFO: sun.java2d.renderer.logUnsafeMalloc = false
INFO: sun.java2d.renderer.curve_len_err = 0.01
INFO: sun.java2d.renderer.cubic_dec_d2 = 1.0
INFO: sun.java2d.renderer.cubic_inc_d1 = 0.2
INFO: sun.java2d.renderer.quad_dec_d2 = 0.5
INFO: Renderer settings:
INFO: CUB_DEC_BND = 256.0
INFO: CUB_INC_BND = 51.2
INFO: QUAD_DEC_BND = 128.0
INFO: INITIAL_EDGES_CAPACITY = 98304
INFO: INITIAL_CROSSING_COUNT = 1024
Priority:
MediumMedium
Reporter:
Serge
Hello,
Sometime Geoserver crash with error:
28 May 10:52:49 ERROR [freebsd.FreeBsdCentralProcessor] - Failed syctl call: kern.cp_times, Error code: 12
  1. A fatal error has been detected by the Java Runtime Environment:
  2. SIGSEGV (0xb) at pc=0x0000000802660fc2, pid=972, tid=101066
  3. JRE version: OpenJDK Runtime Environment (11.0.10+9) (build 11.0.10+9-1)
  4. Java VM: OpenJDK 64-Bit Server VM (11.0.10+9-1, mixed mode, tiered, compressed oops, g1 gc, bsd-amd64)
  5. Problematic frame:
  6. V [libjvm.so+0xa60fc2] AsyncGetCallTrace+0xeda02
  7. Core dump will be written. Default location: /usr/home/serge/geoserver-2.19.1/java.core
  8. An error report file with more information is saved as:
  9. /usr/home/serge/geoserver-2.19.1/hs_err_pid972.log
  10. If you would like to submit a bug report, please visit:
  11. https://bugs.freebsd.org/bugzilla/enter_bug.cgi?product=Ports%20%26%20Packages&component=Individual%20Port(s)&short_desc=java/o
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100165-sha1:55cd523)
Atlassian logo
