[Geoserver-devel] [JIRA] (GEOS-10100) Geoserver 2.19 Proxy Base URL
Graham Humphries created an issue
GeoServer / BugGEOS-10100
Issue Type:
BugBug
Affects Versions:
2.19-RC, 2.19.0, 2.19.1
Assignee:
Unassigned
Components:
Configuration
Created:
10/Jun/21 2:20 AM
Environment:
Oracle Solaris 5.11 sparcv9, Tomcat 8.5.60, AdoptOpenJDK 1.8.0_275-b01
Priority:
MediumMedium
Reporter:
Graham Humphries
I have set the Proxy Base URL in the Geoserver Global Settings to and the Edit Workspace page to my external URL like https://<myorg>.tas.gov.au/geoserver. This is to allow the differentiation of internal and external users and apply the correct authorisation without requiring users to create a login profile. This configuration has been working since Geoserver 2.11
Since the release of Geoserver 2.19.nn the UI behaviour has changed. If I log in using my internal URL eg http://<server name>:8080/geoserver geoserver redirects to my external URL above. This causes a problem because any Geoserver request that is reverse proxied also has a user authorisation added to the request header. This user obviously does not have an admin role, so I can’t make changes to Geoserver.
I have tested Geoserver versions 2.18.1, 2.18.2, 2.18.3 2.19.RC, 2.19.0 & 2.19.1. It is only the Geoserver versions 2.19.nn that do this.
Can the previous behaviour be restored?
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100166-sha1:b9531e5)
Atlassian logo
