Pressing the validate button on the styles page for a CSS causes the “Oops something went wrong” screen. I have seen a couple of other historical reports on this relating to multiple copies of the asm jar. I have checked and after installing the CSS extension I only have one of each of the following:
{{ asm-util-6.2.1.jar
asm-6.2.1.jar
parboiled-core-1.2.0.jar
asm-analysis-6.2.1.jar
parboiled-java-1.2.0.jar
gt-brewer-25-SNAPSHOT.jar
gs-css-2.19-SNAPSHOT.jar
gt-css-25-SNAPSHOT.jar
asm-tree-6.2.1.jar }}
The caused by sections of the error are as follows:
> Caused by: java.lang.reflect.InvocationTargetException
> at jdk.internal.reflect.GeneratedMethodAccessor313.invoke(Unknown Source)
> at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
> at java.base/java.lang.reflect.Method.invoke(Method.java:566)
> at org.apache.wicket.RequestListenerInterface.internalInvoke(RequestListenerInterface.java:258)
> … 122 more
> Caused by: java.lang.NoSuchMethodError: ‘java.util.Map org.geotools.styling.Rule.getOptions()’
> at org.geotools.brewer.styling.builder.RuleBuilder.build(RuleBuilder.java:190)
> at org.geotools.brewer.styling.builder.FeatureTypeStyleBuilder.build(FeatureTypeStyleBuilder.java:162)
> at org.geotools.brewer.styling.builder.StyleBuilder.build(StyleBuilder.java:95)
> at org.geotools.styling.css.CssTranslator.translate(CssTranslator.java:333)
> at org.geoserver.community.css.web.CssHandler.convertToSLD(CssHandler.java:150)
> at org.geoserver.community.css.web.CssHandler.validate(CssHandler.java:167)
> at org.geoserver.wms.web.data.AbstractStylePage.validateSLD(AbstractStylePage.java:687)
> at org.geoserver.wms.web.data.AbstractStylePage$14.onClick(AbstractStylePage.java:650)
> at org.geoserver.web.wicket.GeoServerAjaxFormLink.onSubmit(GeoServerAjaxFormLink.java:45)
> at org.apache.wicket.ajax.markup.html.form.AjaxSubmitLink$1.onSubmit(AjaxSubmitLink.java:111)
> at org.apache.wicket.ajax.form.AjaxFormSubmitBehavior$AjaxFormSubmitter.onSubmit(AjaxFormSubmitBehavior.java:215)
> at org.apache.wicket.markup.html.form.Form.onFormSubmitted(Form.java:787)
> at org.apache.wicket.ajax.form.AjaxFormSubmitBehavior.onEvent(AjaxFormSubmitBehavior.java:171)
> at org.apache.wicket.ajax.AjaxEventBehavior.respond(AjaxEventBehavior.java:155)
> at org.apache.wicket.ajax.AbstractDefaultAjaxBehavior.onRequest(AbstractDefaultAjaxBehavior.java:601)
