[Geoserver-devel] [JIRA] (GEOS-10131) GeoServer problems with JDK 16 / SpringFramework
Tobias Warneke created an issue
GeoServer / BugGEOS-10131
Issue Type:
BugBug
Affects Versions:
2.18.3
Assignee:
Unassigned
Components:
WFS
Created:
01/Jul/21 8:21 AM
Environment:
JDK 16
Priority:
MediumMedium
Reporter:
Tobias Warneke
As far as I tested it there is only one major issue for GeoServer regarding JDK >= 12.
2021-07-01 07:44:07,433 ERROR [org.geoserver.ows] (default task-32) : java.lang.IllegalArgumentException: Unsupported class file major version 60
        at deployment.geoserver.war//org.springframework.asm.ClassReader.<init>(ClassReader.java:184)
        at deployment.geoserver.war//org.springframework.asm.ClassReader.<init>(ClassReader.java:166)
        at deployment.geoserver.war//org.springframework.asm.ClassReader.<init>(ClassReader.java:152)
        at deployment.geoserver.war//org.springframework.asm.ClassReader.<init>(ClassReader.java:273)
        at deployment.geoserver.war//org.springframework.cglib.proxy.BridgeMethodResolver.resolveAll(BridgeMethodResolver.java:68)
        at deployment.geoserver.war//org.springframework.cglib.proxy.Enhancer.emitMethods(Enhancer.java:1241)
        at deployment.geoserver.war//org.springframework.cglib.proxy.Enhancer.generateClass(Enhancer.java:726)
        at deployment.geoserver.war//org.springframework.cglib.core.DefaultGeneratorStrategy.generate(DefaultGeneratorStrategy.java:25)
        at deployment.geoserver.war//org.springframework.cglib.core.AbstractClassGenerator.generate(AbstractClassGenerator.java:358)
        at deployment.geoserver.war//org.springframework.cglib.proxy.Enhancer.generate(Enhancer.java:585)
        at deployment.geoserver.war//org.springframework.cglib.core.AbstractClassGenerator$ClassLoaderData$3.apply(AbstractClassGenerator.java:110)
        at deployment.geoserver.war//org.springframework.cglib.core.AbstractClassGenerator$ClassLoaderData$3.apply(AbstractClassGenerator.java:108)
        at deployment.geoserver.war//org.springframework.cglib.core.internal.LoadingCache$2.call(LoadingCache.java:54)
        at java.base/java.util.concurrent.FutureTask.run(Unknown Source)
        at deployment.geoserver.war//org.springframework.cglib.core.internal.LoadingCache.createEntry(LoadingCache.java:61)
        at deployment.geoserver.war//org.springframework.cglib.core.internal.LoadingCache.get(LoadingCache.java:34)
        at deployment.geoserver.war//org.springframework.cglib.core.AbstractClassGenerator$ClassLoaderData.get(AbstractClassGenerator.java:134)
        at deployment.geoserver.war//org.springframework.cglib.core.AbstractClassGenerator.create(AbstractClassGenerator.java:319)
        at deployment.geoserver.war//org.springframework.cglib.proxy.Enhancer.createHelper(Enhancer.java:572)
        at deployment.geoserver.war//org.springframework.cglib.proxy.Enhancer.create(Enhancer.java:406)
        at deployment.geoserver.war//org.geoserver.wfs.GetFeature.run(GetFeature.java:832)
        at deployment.geoserver.war//org.geoserver.wfs.DefaultWebFeatureService.getFeature(DefaultWebFeatureService.java:105)
This problem occurs due to the use of SpringFramework version 5.1.20.RELEASE. Here the opcode enhancer does only recognize JDK til version 12. SpringFramework 5.3.x is able to handle opcode enhancing til java 16 and higher.
So when do you intend to upgrade? GeoServer is the last app in stack that would hinder us to go with JDK 16 or higher.
Regards Tobias
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100167-sha1:712c0be)
Atlassian logo
