Nuno Silva created an issue |
Issue Type: |
Bug |
Affects Versions: |
2.19.1 |
Assignee: |
Unassigned |
Components: |
Community modules |
Created: |
06/Jul/21 1:27 PM |
Priority: |
Medium |
Reporter: |
I’m trying to use the OGR Datastore plugin to read some GeoRSS feed, but when I run Geoserver behind corporation proxy I can’t get any results… When I put together the same Geoserver 2.19.1 + Tomcat 9 + Ubuntu Server 18.04 with direct access to the internet, there is no problem with the datastore configuration and publishing the layers. When using the ogrinfo command from cli of Ubuntu Server: ogrinfo https://emergency.copernicus.eu/mapping/activations-rapid/feed -ro Output of log file catalina.out when I use the Geoserver GUI to add a OGR datastore: ERROR 1: Failed to connect to emergency.copernicus.eu port 443: Connection timed out OGR datastore plugin: https://build.geoserver.org/geoserver/2.19.x/community-2021-07-02/geoserver-2.19-SNAPSHOT-ogr-datastore-plugin.zip GeoRSS feed example: Ubuntu Server ENV variables:
Tomcat Service configured with proxy information configured |
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS |
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100168-sha1:3232b41) |
