Andre Schardong created an issue |
Issue Type: |
Improvement |
Affects Versions: |
2.19.2 |
Assignee: |
Unassigned |
Attachments: |
out.txt |
Created: |
18/Aug/21 10:44 PM |
Environment: |
Windows 11 - |
Priority: |
Medium |
Reporter: |
I know windows 11 is probably not supported, however I’m facing this issue when starting Geoserver. Was working fine before update (windows 10).
I have tried different versions of Java (x86 64bits, java 8-301 and others) same issue.
18 Aug 21:26:59 ERROR [context.ContextLoader] - Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘OSHISystemInfoCollector’ defined in URL [jar:file:/C:/Geoserver/webapps/geoserver/WEB-INF/lib/gs-main-2.19.2.jar!/org/geoserver/system/status/OSHISystemInfoCollector.class]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Failed to instantiate [org.geoserver.system.status.OSHISystemInfoCollector]: Constructor threw exception; nested exception is java.lang.IllegalStateException: Unmapped relationship: 7
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.instantiateBean(AbstractAutowireCapableBeanFactory.java:1300)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:1195)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:554)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:514)
at org.springframework.beans.factory.support.AbstractBeanFactory.lambda$doGetBean$0(AbstractBeanFactory.java:321)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:234)
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS |
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100174-sha1:7655f04) |
