Jody Garnett created an issue |
release note links no longer public and require login to atlassian.net |
Issue Type: |
Task |
Assignee: |
Unassigned |
Components: |
Documentation, release |
Created: |
18/Sep/21 12:33 AM |
Environment: |
internet |
Priority: |
Low |
Reporter: |
The release note workflow has changed, and is now used to produce text or markdown content which you can save into another application. > 7. Selecting the ‘Create’ button will generate the release notes using the specified template in the specified format. The release notes will be displayed on screen and can be copied and pasted to another application. What a bother, this means that all our prior release notes are no longer “public” and at the very least require login to atlassian.net (indeed I am not sure what permission is required to see release notes, it could only be available to the project team): Examples: Of course our prior releases already had broken links: |
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS |
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100177-sha1:149c709) |
