[Geoserver-devel] [JIRA] (GEOS-10267) The app-schema-tutorial doesn't work. Data store connection parameters aren't correct. Feature type schema isn't loaded
Lukasz Kujawiak created an issue
GeoServer / BugGEOS-10267
The app-schema-tutorial doesn’t work. Data store connection parameters aren’t correct. Feature type schema isn’t loaded
Issue Type:
BugBug
Affects Versions:
2.19.2
Assignee:
Unassigned
image-2021-10-07-11-45-36-536.png, image-2021-10-07-11-47-18-097.png, image-2021-10-07-11-49-10-899.png
Components:
Documentation
Created:
07/Oct/21 11:51 AM
Environment:
Docker container https://github.com/kartoza/docker-geoserver
Priority:
MediumMedium
Reporter:
Lukasz Kujawiak
I came across two issues related to the app-schema-tutorial published on Github https://github.com/geoserver/geoserver/tree/main/data/app-schema-tutorial
  1. The datastore definition doesn’t work out of the box
Error message taken from layers section: Failed to load attribute list, internal error is: Failed to find the datastore factory for gsml_MappedFeature, did you forget to install the store extension jar?
I was able to fix it by changing the datastore configuration connection parameters:
e.g:
<connectionParameters>
<entry key=“namespace”>urn:cgi:xmlns:CGI:GeoSciML:2.0</entry>
<entry key=“dbtype”>app-schema</entry>
<entry key=“directory”>file:workspaces/gsml/gsml_GeologicUnit/gsml_GeologicUnit.properties</entry>
<entry key=“url”>file:workspaces/gsml/gsml_GeologicUnit/gsml_GeologicUnit.xml</entry>
</connectionParameters>
  1. The schema isn’t loaded
2021-10-07 09:48:39,638 WARN [org.geoserver.catalog] - Error while getting feature type, flushing cache and retrying: Schema ‘GeologicUnit’ does not exist.
2021-10-07 09:48:39,641 WARN [org.geoserver.catalog] - Unable to flush 'urn:cgi:xmlns:CGI:GeoSciML:2.0:GeologicUnit
java.io.IOException: Schema ‘GeologicUnit’ does not exist.
at org.geotools.data.store.ContentDataStore.ensureEntry(ContentDataStore.java:533)
at org.geotools.data.store.ContentDataStore.getFeatureSource(ContentDataStore.java:331)
at org.geotools.data.store.ContentDataStore.getFeatureSource(ContentDataStore.java:303)
at org.geoserver.catalog.ResourcePool.flushState(ResourcePool.java:2672)
at org.geoserver.catalog.ResourcePool.flushDataStore(ResourcePool.java:2645)
at org.geoserver.catalog.ResourcePool.getFeatureType(ResourcePool.java:929)
at org.geoserver.catalog.ResourcePool.getFeatureType(ResourcePool.java:915)
at org.geoserver.catalog.impl.FeatureTypeInfoImpl.getFeatureType(FeatureTypeInfoImpl.java:123)
at jdk.internal.reflect.GeneratedMethodAccessor260.invoke(Unknown Source)
at
I wasn’t able to find the solution
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100180-sha1:9ba4f0d)
Atlassian logo
