Stefano Pezzi created an issue |
WFS GetFeature raises error when querying layers built on 3/4 dimensional shapefiles |
Issue Type: |
Bug |
Affects Versions: |
2.17.5, 2.18.5, 2.19.3, 2.20.0 |
Assignee: |
Unassigned |
Attachments: |
ticketGEOS.zip |
Created: |
28/Oct/21 3:45 PM |
Environment: |
Windows 10, Tomcat 9.0.54, Java jdk-11.0.12.7-hotspot (Adoptium by Eclipse Foundation) |
Priority: |
Medium |
Reporter: |
The WFS’s request GetFeature fails when querying layer defined on shapefile that have more than 2 dimensions.
The XYZM and XYZ test cases give the same error “Invalid ordinate index: 3.”
Excerpt from logfile:
java.lang.IllegalArgumentException: Invalid ordinate index: 3
at org.locationtech.jts.geom.Coordinate.setM(Coordinate.java:218)
at org.locationtech.jts.geom.impl.PackedCoordinateSequence.getCoordinate(PackedCoordinateSequence.java:116)
at org.locationtech.jts.operation.predicate.RectangleIntersectsSegmentVisitor.checkIntersectionWithSegments(RectangleIntersects.java:327)
at org.locationtech.jts.operation.predicate.RectangleIntersectsSegmentVisitor.checkIntersectionWithLineStrings(RectangleIntersects.java:317)
at org.locationtech.jts.operation.predicate.RectangleIntersectsSegmentVisitor.visit(RectangleIntersects.java:310)
at org.locationtech.jts.geom.util.ShortCircuitedGeometryVisitor.applyTo(ShortCircuitedGeometryVisitor.java:35)
at org.locationtech.jts.operation.predicate.RectangleIntersects.intersects(RectangleIntersects.java:110)
at org.locationtech.jts.operation.predicate.RectangleIntersects.intersects(RectangleIntersects.java:58)
at org.locationtech.jts.geom.Geometry.intersects(Geometry.java:754)
at org.geotools.filter.spatial.BBOXImpl.basicEvaluate(BBOXImpl.java:118)
at org.geotools.filter.spatial.BBOXImpl.evaluateInternal(BBOXImpl.java:107)
The XYM test case gives an “Index 69 out of bounds for length 69”
java.lang.ArrayIndexOutOfBoundsException: Index 69 out of bounds for length 69
at org.geotools.geometry.jts.LiteCoordinateSequence.setOrdinate(LiteCoordinateSequence.java:224)
at org.geotools.data.shapefile.shp.PolygonHandler.readCoordinates(PolygonHandler.java:315)
at org.geotools.data.shapefile.shp.PolygonHandler.read(PolygonHandler.java:142)
at org.geotools.data.shapefile.shp.ShapefileReader$Record.shape(ShapefileReader.java:114)
at org.geotools.data.shapefile.ShapefileFeatureReader.getGeometry(ShapefileFeatureReader.java:239)
at org.geotools.data.shapefile.IndexedShapefileFeatureReader.hasNext(IndexedShapefileFeatureReader.java:86)
at org.geotools.data.ReTypeFeatureReader.hasNext(ReTypeFeatureReader.java:191)
at org.geotools.data.MaxFeatureReader.hasNext(MaxFeatureReader.java:82)
WMS’s GetMap and GetFeatureInfo work fine, but we had some problems with simple WPS’s processes that are probably linked to the same issue.
Attached are 4 shapefile with MultiPolygon, MultiPolygonZ, MultiPolygonM and MultiPolygonZM geometries respectively and a text file with the CURLed WFS GetFeatures. ticketGEOS.zip
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS |
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100183-sha1:4a12dee) |
