[Geoserver-devel] [JIRA] (GEOS-10326) viewParams are automatically upper cased for SQL View Layer
Tobias Warneke created an issue
GeoServer / BugGEOS-10326
Issue Type:
BugBug
Affects Versions:
2.18.4
Assignee:
Unassigned
Created:
08/Dec/21 10:18 AM
Priority:
MediumMedium
Reporter:
Tobias Warneke
I created a parameterized sql view layer. It works so far with a SQL like this:
select geom from mytable where id=%id%
Now within my request I construct something like
http://server/geoserver/myworkspace/ows?SERVICE=WMS&LAYERS=mylayer&... &VIEWPARAMS=id:5&...
Within GeoServers log I see witin RawKvp, that my parameters are read by the server, but the viewparam is not put into my SQL.
At the end of this GetMap log output I see a line
 ViewParams = [{ID=5}]
The parameter name is suddenly uppercased.
So if I change my SQL to
select geom from mytable where id=%ID%
and make the parameter name in the layer configuration uppercased as well, all works fine, even if I request my viewparams in lower case.
I consider this a bug. Or is this by intention?
Unfortunately I could not locate the problematic code line.
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100183-sha1:f6eba4b)
Atlassian logo
