[Geoserver-devel] [JIRA] (GEOS-10351) [GSIP 206] Promote GeoPackage WFS and WMS output formats to an extension
Jody Garnett created an issue
GeoServer / New FeatureGEOS-10351
Issue Type:
New FeatureNew Feature
Assignee:
Jody Garnett
Components:
geopackage, WFS, WMS
Created:
07/Jan/22 3:33 AM
Priority:
MediumMedium
Reporter:
Jody Garnett
The http://www.geopackage.org standard is now a popular data format, and GeoPackage data source has been included with GeoServer as a data source for some time.
We would like to make the WFS and WMS GeoPackage output formats from the GeoPackage community module available as an extension.
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100187-sha1:07b4f58)
Atlassian logo
Hi Jody,
I am in favor of making it an extension to ensure maintenance.
However, I am still not in favor of GeoPKG to become a “supported” output for WMS and WFS unless there is a working solution to prevent (unintentional) denial of service requests. A simple feature or layer count might not be sufficient… What if a user starts the production of a humongous GeoPKG accidentally? There is no way to stop it!? You need something like asynchronous processing …
Not mentioned explicitly, but fixing https://osgeo-org.atlassian.net/browse/GEOT-7011 is in scop, right?
Andreas
Date: Friday, 7. January 2022 at 03:33
To: Geoserver Devel geoserver-devel@lists.sourceforge.net
Subject: [Geoserver-devel] [JIRA] (GEOS-10351) [GSIP 206] Promote GeoPackage WFS and WMS output formats to an extension
Image removed by sender.
Issue Type:
Assignee:
Jody Garnett
Components:
Created:
07/Jan/22 3:33 AM
Priority:
MediumMedium
Reporter:
Jody Garnett
Add Comment
Add Comment
Atlassian logo
_______________________________________________ Geoserver-devel mailing list Geoserver-devel@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-devel
(attachments)
jira-generated-image-static-footer-desktop-logo-69c894ba-aed2-4a3e-9c96-39c67562529d.png
I have a fix for GEOT-7011 but that is a separate issue and not part of the proposal.
The existing restrictions on WFS output are sufficient to keep a system stable with shapefile or geopackage output.
You can use control flow to place further limitations on a specific output format (indeed this is the module focused on denial of service).
WPS output offers async if required for massive content.
(attachments)
Jody Garnett
Hi Jody,
That is great! Could you please alert me once the fix for 7011 is included in a Geoserver build. I am happy to update my code then and run the axis order confusion tests to make sure…
Andreas
Date: Tuesday, 11. January 2022 at 22:39
To: Andreas Matheus / Secure Dimensions am@anonymised.com
Cc: “Jody Garnett (JIRA)” jira@anonymised.com, Geoserver Devel geoserver-devel@lists.sourceforge.net
Subject: Re: [Geoserver-devel] [JIRA] (GEOS-10351) [GSIP 206] Promote GeoPackage WFS and WMS output formats to an extension
Jody Garnett
On Sun, 9 Jan 2022 at 23:40, Andreas Matheus / Secure Dimensions <am@anonymised.com> wrote:
Hi Jody,
Andreas
To: Geoserver Devel <geoserver-devel@lists.sourceforge.net>
Error! Filename not specified.
Issue Type:
Assignee:
Jody Garnett
Components:
Created:
07/Jan/22 3:33 AM
Priority:
MediumMedium
Reporter:
Jody Garnett
Add Comment
Add Comment
Atlassian logo
_______________________________________________ Geoserver-devel mailing list Geoserver-devel@anonymised.comts.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-devel
(attachments)
Andreas,
The fix for GEOT-7011 is here;
https://github.com/geotools/geotools/pull/3740
If you have the time, please review.
David
On Tue, Jan 11, 2022 at 11:05 PM Andreas Matheus / Secure Dimensions <am@anonymised.com> wrote:
Hi Jody,
Andreas
To: Andreas Matheus / Secure Dimensions <am@anonymised.com>
Cc: “Jody Garnett (JIRA)” <jira@anonymised.com>, Geoserver Devel <geoserver-devel@anonymised.comsts.sourceforge.net>
Jody Garnett
Hi Jody,
Andreas
From: “Jody Garnett (JIRA)” <jira@anonymised.com4247…>
Issue Type:
Assignee:
Jody Garnett
Components:
Created:
07/Jan/22 3:33 AM
Priority:
MediumMedium
Reporter:
Jody Garnett
Add Comment
Add Comment
Atlassian logo
_______________________________________________ Geoserver-devel mailing list Geoserver-devel@anonymised.comt https://lists.sourceforge.net/lists/listinfo/geoserver-devel
(attachments)
