Jan Tjalling Wal, van der created an issue |
Issue Type: |
Bug |
Affects Versions: |
2.20.1 |
Assignee: |
Unassigned |
Attachments: |
Re Geoserver-users Flaw in Service activation.msg |
Components: |
WMS |
Created: |
24/Jan/22 10:10 AM |
Environment: |
Priority: |
Medium |
Reporter: |
The issue was noticed a few weeks after an upgrade to 2.20.1. Geoserver-layers that had been wms-only, were found to be offered with WFS-service as well. The issue may therefore be related to upgrades. With the upgrade failing to set/reset the rights as per the previous version. While trying to fix following unexpected behaviour was noticed: Starting from the top (workspace), In this case all wms-only layers are grouped in the same workspace: WMRwms. Activated the WFS-override options check box. Set the WFS to disabled. Saved the settings. Reloaded the configuration and catalog. Checked to see if the WFS was no longer available for the layers in WMRwms. Still there. Redid similar actions for the stores (one level down) that are involved. Next I went to each individual layer and there moved the WFS-service to the disabled services (on the right). Only then the the WFS-services where removed (no longer offered). BUG 1) Disabling WFS-services at the level of workspaces or stores does not propagate correctly to the layers contained within them. BUG 2) This error may get introduced during an upgrade. Ours was 2.19.x to 20.20.1. Attached mail-message should provide further details an includes some screenshots. |
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS |
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100189-sha1:aa9f0ed) |
