[Geoserver-devel] [JIRA] (GEOS-10419) NullPointerException from GeoServerOAuthAuthenticationFilter
Pascallike created an issue
GeoServer / BugGEOS-10419
Issue Type:
BugBug
Affects Versions:
2.20-RC
Assignee:
Unassigned
Components:
OAuth2
Created:
15/Mar/22 9:51 AM
Environment:
kartoza/geoserver with sec-oauth2-openid plugin
Priority:
LowLow
Reporter:
Pascallike
I’m getting this exception from WMS getMap requests when I’m trying to access a public layer with an anonymous user:
java.lang.NullPointerException
org.geoserver.security.oauth2.GeoServerOAuthAuthenticationFilter.doFilter(GeoServerOAuthAuthenticationFilter.java:134)
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:334)
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:71)
org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:105)
org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:75)
org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:215)
org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:178)
org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:142)
org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:358)
org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:271)
org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:102)
org.geoserver.filters.XFrameOptionsFilter.doFilter(XFrameOptionsFilter.java:77)
org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:48)
org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:49)
org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:42)
org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:201)
org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:119)
This happens randomly, but quite frequently (about 1 out of 20 requests to the server). It never happens after login, so limited to anonymous users.
The exception starts from this line of code:
https://github.com/geoserver/geoserver/blob/main/src/community/security/oauth2-core/src/main/java/org/geoserver/security/oauth2/GeoServerOAuthAuthenticationFilter.java#L134
import javax.servlet.http.HttpServletRequest;
HttpServletRequest httpRequest = (HttpServletRequest) request;
httpRequest.getSession(false).invalidate();  <--- NullPointerException
Testing locally I found that the exception is thrown by the HttpSession.invalidate() on a null object. So the HttpServletRequest.getSession(false) could be null. I’m not able to tell if the null session at this point is a problem, but considering that HttpServletRequest.getSession(false) could be null, I’ve added a check for null object on the session before running the HttpSession.invalidate(), that seems to fix the problem.
Please let me know if you think it might be a good idea to add this control to GeoServer or if you are aware of the problem. I can open a Pull Request to add the fix.
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100197-sha1:8522567)
Atlassian logo
