[Geoserver-devel] [JIRA] (GEOS-10420) GeoFence group list is too limiting
Emanuele Tajariol created an issue
GeoServer / ImprovementGEOS-10420
Issue Type:
ImprovementImprovement
Assignee:
Unassigned
Components:
GeoFence
Created:
15/Mar/22 10:57 AM
Priority:
MediumMedium
Reporter:
Emanuele Tajariol
When the option “Use GeoServer roles to get authorizations” is used, the logic requires a list of predefined groups, so that the last matching group (a break is missing?) is used for the authorization in GeoFence
see https://github.com/geoserver/geoserver/blob/84557570531bda5d9ce03703bba379fb2a4b1cfa/src/extension/geofence/src/main/java/org/geoserver/geofence/GeofenceAccessManager.java#L572
In architectures where the authentication is plugged, we may not know in advance the list of available roles, so we may want just take any role (probably there will be only one assigned when the user logs in).
We may add regex handling in this list, but, in order not to overengineer the logic, we may just consider the case where the “Comma delimited list of mutually exclusive roles for authorization” only contains a “*”; in that case, the first group associated to the current user should be used.
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100197-sha1:8522567)
Atlassian logo
