[Geoserver-devel] [JIRA] (GEOS-10423) NullPointerException: GWC Layer MISS
Sander Mol created an issue
GeoServer / BugGEOS-10423
Issue Type:
BugBug
Affects Versions:
2.20.2, 2.20.3
Assignee:
Unassigned
geoserver-error.log
Components:
GWC
Created:
16/Mar/22 2:33 PM
Priority:
MediumMedium
Reporter:
Sander Mol
Problem
Whenever I request a tile that is not cached (geowebcache-cache-result: MISS), I get a null pointer exception without a geowebcache-miss-reason header.
URL: https://<redacted-geoserver-url>/geoserver/ows/wms/?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&FORMAT=image/png&TRANSPARENT=true&LAYERS=<redacted-layer-name>&WIDTH=256&HEIGHT=256&CRS=EPSG:4326&STYLES=&BBOX=51.94061279296875,5.086669921875,51.943359375,5.08941650390625&exceptions=application/json
After a second run, and the tile is cached (geowebcache-cache-result: HIT), I no longer get this error in GeoServer.
Set up
The GWC set up uses “direct WMS integration” and uses “no explicit TILED parameter”.
Error
Full logs as an attachment.
> 6 Mar 13:06:13 ERROR [org.geoserver.ows] -
> java.lang.NullPointerException
> at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:76)
> at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:41)
> at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:186)
> at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:51)
> at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:212)
Please let me know if more information is needed. To me, it looks like the missing geowebcache-miss-reason header might be related to the actual problem, but I am unsure how to debug this further.
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100197-sha1:e769b43)
Atlassian logo
