[Geoserver-devel] [JIRA] (GEOS-10456) Compute from data does not swap X and Y when the native CRS axis order is NORTH-EAST
Daniel Singh created an issue
GeoServer / BugGEOS-10456
Issue Type:
BugBug
Affects Versions:
2.20.3
Assignee:
Unassigned
Components:
web
Created:
08/Apr/22 10:45 PM
Priority:
LowLow
Reporter:
Daniel Singh
When setting the bounding box for a layer, the button which says ‘Compute from data’ will parse the correct values but will always assume they are in the right X-Y order. However, some CRSs have a NORTH-EAST axis order (Y-X). The user can change the values around manually but its an annoyance and sort of defeats the object of the ‘Compute from data’ button
An example can be seen in the table below which uses the capabilities here: https://data.linz.govt.nz/services;key=c68d2c90bf2546d5aa1189b5fc1c18d6/wmts/1.0.0/layer/51769/WMTSCapabilities.xml
Min X
Min Y
Max X
Max Y
WRONG (what ‘Compute from data’ does)
3,087,000
274,000
7,173,000
3,327,000
SHOULD BE
274,000
3,087,000
3,327,000
7,173,000
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100198-sha1:943baf4)
Atlassian logo
